The car is off the road every year for 5 to 6 months (on trickle charger) and there are always codes when i restart. i disconnect the negative battery cable and all is well. this year that did not happen.
The car drives fine except when i get the “service stabilitrak” light come on, the car goes into limp mode for 10 seconds then drives fine. i have been getting the “service stabilitrak” warning since i bought the car and has been to the dealer multiple times with no answer.
i get the “service stabilitrak” warning light when i drive the car hard, accelerate hard. the spark plugs, coils & fuel injectors have all been changed with no luck.
i did buy a new battery but the codes persist.
1 power steering control module code
u0121 lost communication with anti-lock brake system (abs) control module
1 anti-lock brake system code
u0401 invalid data received from ECM/PCM ‘a'
2 suspension control codes
u0100 lost communication with ECM/PCM 'a'
1 engine control module code
p0300 random/multiple cylinder misfire detected
4 body control module codes
b3205 lf/driver window motor circuit malfunction
b3210 rf/passenger window motor circuit malfunction
b3215 lr window motor circuit malfunction
Jun 3, 2025 at 4:12 AM
