Multiple Alternator Replacements
2008 TOYOTA RAV4
120,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
HARIMANDIR S KHALSA
  • 6 POSTS
All of the check lights went on with the car (check engine light, battery light, all of them), and the car was driving strangely. I had the alternator checked, and it was bad, but the battery was good. I replaced the alternator, but didn't tighten down the battery clamps very well after replacing the alternator. The replacement alternator went bad and the battery went bad. I replaced the battery and securely tightened the battery down with the clamps, and put in another alternator, but the battery light comes on and off intermittently while driving. I had it checked and the alternator is bad again. I checked the fuses to see if any of them were visibly bad, especially the fuses that pertain to the alternator. I checked cables to see if I could find any issues there, but the cables and fuses all look ok. I haven't tested fuses with a multimeter yet. What could be causing the alternator go keep going bad?
Sep 21, 2025 at 9:24 PM
If you don't use a high quality alternator like a Denso they will go out quickly. If you have a good alternator on there it can be over worked due to a bad battery current sensor. Here is the location of the sensor so you can swap it out. You can help confirm the issue if you use a voltameter to test he alternator output while the engine is on by following this guide.
Check out the images (below). Let us know what you find.
Sep 22, 2025 at 4:47 PM
HARIMANDIR S KHALSA
  • 6 POSTS
Thank you for the info. I ordered a denso oem alternator, because the alternator from the local parts store kept failing. Even a local mechanic checked it out and said it's the alternator that's bad, no other underlying cause found. Also, is there a serpentine belt removal wrench you would recommend for a 2008 rav4? I bought an inexpensive one, which hasn't worked very well.
Sep 29, 2025 at 2:24 PM
Yep, sometimes you got to with the a name brand. This is the wrench they show does your look like this? Check out the images (below). Please upload pictures or videos in your response
Sep 29, 2025 at 4:41 PM
