Cranks not starting
1977 DODGE 440
88 MILES
REGINAB38
  • 9 POSTS
I turn the ignition and it cranks but it doesn't start. it sounds like it wants to but it won't. it was running just fine two days ago and the carburetor flap keeps getting stuck. Also, the vehicle listed above is a motorhome.
May 11, 2020 at 1:40 AM
Good morning,
If the choke plate is stuck closed, it will flood the engine on cold starts.
You need to take a screw driver and open it a little bit for air to get into the intake so it will start. If that does get it started, you will need to have the flap fixed so it does not stick.
Can you post a picture of the carburetor with the air filter off?
May 11, 2020 at 4:37 AM
REGINAB38
  • 9 POSTS
This is one picture you wanted to see.
May 11, 2020 at 12:01 PM
REGINAB38
  • 9 POSTS
I am sending another.
May 11, 2020 at 12:08 PM
REGINAB38
  • 9 POSTS
This was to Roy.
May 11, 2020 at 12:09 PM
REGINAB38
  • 9 POSTS
Okay, also if that does get it started by taking a screw driver and opening the flap what do I need to do to fix the flap? also if that doesn't get it started what could be another problem it won't start?
May 11, 2020 at 12:12 PM
Thank you. That is the old thermoquad. That does not have a good history.
You need to free up the choke plate and make it move freely or you will need to replace the carburetor. I doubt anyone around will rebuild it for you. You would need an old timer like myself to do that and we are all slowly retiring leaving no one to fix these.
I attached a rebuilt one from rock auto for you to view.
May 11, 2020 at 12:13 PM
REGINAB38
  • 9 POSTS
How do you know if you have to replace the whole carburetor already what will be the signs of that?
May 11, 2020 at 9:05 PM
The flap is the issue you described.
You need to have someone look at this and see if they can fix it for you.
If they cannot then the option is to replace the carb assembly. That is the last resort if the choke plate cannot be freed up.
May 12, 2020 at 2:08 AM
REGINAB38
  • 9 POSTS
You said to take a screwdriver and open the flap. how do I do that? where do I unscrew?
May 12, 2020 at 11:10 AM
REGINAB38
  • 9 POSTS
Also where is the choke plate at?
May 12, 2020 at 11:11 AM
REGINAB38
  • 9 POSTS
Here is a video.
May 12, 2020 at 11:13 AM
You do not unscrew anything. You open the choke plate and use the screw driver to hold the plate open while you crank it.
