Okay, I would check the rotation of the engine manually, this video can help:
https://www.youtube.com/watch?v=oN42gZN6gOE
If you can turn the engine over by hand it sounds like you have a defective starter motor which is common. If the start trigger wire is getting power and the main power is connected allow with the main ground from the battery to the engine the starter is bad. Can I ask if the battery is in good shape?
Please go over this video as well:
https://www.youtube.com/watch?v=6YRW8fyNudY&t
Here are the wiring diagrams for the starter motor so you can see how the system works.
I marked the wiring diagrams to show you which wire to test for power while in the crank position.
You may have a starter relay that is not working, but we will get to that once you run these tests. Please upload a video in your response. Check out the images (below).
Mar 19, 2025 at 11:17 AM
