Engine shut off while driving and will not start
1996 FORD ESCORT
140,000 MILES • 1.9L • 2WD • AUTOMATIC
LITTLEDEVILME
Driving home the motor shut down. I plugged in A code reader it said to replace camshaft sensor which I did. Car still won't start. Plugged in code reader again this time no codes. Replaced fuel filter and fuel pump still won't start.
Jul 14, 2021 at 4:42 PM
SQM
  • 6,383 POSTS
Did you check to make sure you are getting the correct fuel pressure? It should be around 35 - 40 PSI.
Have check to make sure you are getting spark?
I have attached basic diagnostic procedure as well as fuel pressure check procedure.
Please refer to this article it might be helpful:
https://www.2carpros.com/articles/engine-stalls
Let me know if you have any questions.
Thank you.
Jul 14, 2021 at 6:44 PM
