Motor will not roll over or engage starter
1970 CHEVROLET NOVA
4,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
NOVAMATT1970
My car has power to everything and battery was tested and was good. But when you turn the key it will not roll over or even engage the starter. If you hook up a battery charger to it on charge it starts up right away though. Car does have a MSD 6AL ignition.
Jun 1, 2018 at 6:30 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
That sounds like the battery terminal connections are loose.
Jun 1, 2018 at 7:35 AM
STEVE W.
  • 15,113 POSTS
Yes, loose or corroded battery connection or poor ground connection would cause that. A marginal connection would still power the lower draw items but when you load it with the high draw starter it cannot carry enough amperage to turn the starter motor over.
Jun 1, 2018 at 7:48 AM
