Motor noise/lock/unlock through remote control?
2012 GMC TERRAIN
210,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
KASSEMELBENDARY
  • 4 POSTS
Recently I had an accident, and the side airbags opened. I repaired the car and remove all the affected airbags. After I remove all sides air bags the lock /unlock through remote control not working. Also, I observed the motor sound high compared to before accident.
Could you please advice?
Sep 13, 2024 at 7:29 AM
I would start by checking the fuses (bcm1), here is a guide to help and I have included the fuse locations in the images below. Also, double check your work to make sure everything is plugged in as it should be. I would check the grounds which if have been left off the locks will not work.
Please start a new thread for the engine noise problem. Check out the images (below). Please let us know what happens.
Sep 13, 2024 at 10:55 AM
KASSEMELBENDARY
  • 4 POSTS
I checked fuse it is working also I double check everything plugged same as before.
Also, there are indication for tire pressure was appearing and I failed to rest it.
Is their relation between remote operation and tire pressure indication .
Sep 20, 2024 at 3:31 AM
There might be, we should do a CAN scan to see which codes are stored which can help see which direction to go in for the repair. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Sep 20, 2024 at 10:30 AM
KASSEMELBENDARY
  • 4 POSTS
I did CAN scan as you can find attached.
Could you provide the installation location of receiver exactly?
Oct 11, 2024 at 2:48 AM
We only handle one problem per thread and it looks like you have may problems, I would clear the codes, then turn the key on and then do another scan, this will give of the most relevant codes to work with. Did they replace the PCM ?
Oct 11, 2024 at 10:37 AM
KASSEMELBENDARY
  • 4 POSTS
No I didn’t replace PCM ?
Oct 11, 2024 at 9:48 PM
Okay, it seems like something is wrong with the voltage supply to the PCM, check out the first three codes, I would try clearing the codes and then turn the ignition system on and then run them again to see which ones are relevant still. The problem is the first code with the eeprom error, you usually see this code whent he PCM was been changed.
Oct 13, 2024 at 8:55 AM
