motor mount replacement
1993 FORD F-150
250,000 MILES • 4.9L • 6 CYL • 4WD
JGANAWAY
  • 42 POSTS
I'm replacing both engine mounts and I forgot to note which way they were before I took them out. I'm putting hydraulic mounts in. Which way do they go?
Aug 2, 2019 at 8:39 PM
Welcome to 2CarPros.
Here are the directions for replacement. The attached picture is an exploded view. You can tell which way they attach.
engine mount
1993 Ford Truck F 150 4WD Pickup L6-300 4.9L
Front
Vehicle Engine, Cooling and Exhaust Engine Drive Belts, Mounts, Brackets and Accessories Engine Mount Service and Repair Procedures Removal and Installation Front
FRONT
Fig. 3 Front engine mounts
Pic 1
1. Remove insulator-to-support bracket attaching nut and washer. If only one insulator is being removed, loosen the opposite insulator at support bracket.
2. Raise engine slightly using a block of wood placed under oil pan and a suitable jack.
3. Remove insulator attaching bolts and the insulator, Fig. 3.
4. Reverse procedure to install.
Aug 2, 2019 at 9:50 PM
