Radiator fan not working
2006 MAZDA 3
143,423 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MONCHO6685
  • 118 POSTS
Hello again, my car have problems with the fan. i put 12 volts directly to the fan and it works perfectly, but when it's on the car it won't work properly. it has a control module. How i test that module? And i notice that it try to work, but it slow or try to operate start slowly and stop. The car have fan and coolant sensor or it works with the coolant only?
Where it's or it located? Can you show me? it also have a relay.
Where i start?
Thanks.
Att. Juan marin
Apr 3, 2019 at 9:31 AM
JOETECHPRO
  • 705 POSTS
Hey MONCHO6685,
Are you talking about the interior heater fan or the radiator/condenser fan under the hood?
Regards, Joe
Apr 3, 2019 at 5:40 PM
MONCHO6685
  • 118 POSTS
Radiator/condenser under the hood, sorry for not indicate which one.
Att. Juan marin.
Thanks
Apr 4, 2019 at 5:52 AM
JOETECHPRO
  • 705 POSTS
Hey MONCHO6685,
Ok, no problem just wanted to be sure.
So you do have a cooling fan control module. The control is either from the Coolant temperature sensor on an input from the A/C.
With the engine running A/C on does the fan run?
With the engine running A/C on can you please unplug the fan and test for voltage between the two pins on the fan plug?
Let me know what you have.
Regards, Joe
Apr 4, 2019 at 10:22 AM
MONCHO6685
  • 118 POSTS
Yes, it has current. I think it's the coolant sensor,¿maybe? Oh, you think is something else. If it's the coolant sensor? Where i found it? Thanks to all the technicians that bring me support. I learn a lot from your expertise.
Apr 8, 2019 at 1:10 PM
JOETECHPRO
  • 705 POSTS
Hey MONCHO6685,
So the fan does run with the A/C on?
Regards, Joe
Apr 8, 2019 at 8:46 PM
MONCHO6685
  • 118 POSTS
the problem now is that when i stop the engine and let it rest all night, when i start the engine in the morning the gauge is in hot. this happen so many times. I think that the ect is out of service. what you can tell me? thanks.
att. juan marin.
May 1, 2019 at 11:40 AM
MONCHO6685
  • 118 POSTS
ok i'll do it an let you know. thanks.
the entire fan is new, module, all the assembly is new.
May 1, 2019 at 11:54 AM
There are fuse and fan controller that run the system here is a guide and the cooling fan wiring diagrams so you can see how the system works with the fuse and module locations as well. The module is next to the fan motor
and
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
May 1, 2019 at 1:03 PM
