Yesterday, I did more test recommended due to the codes retrieved by a scanner. Alldata required Pins 1,2, and 3 to illuminate brightly. Nevertheless, only Pins 1 and 2 illuminated test light brightly, using DVOM it increased in volt when ignition was on, there was continuity in all 3 wires from TCM to the clutch solenoid circuit at the gear. However, the Ohms were too low but I was seeing 15 Ohms. Lastly, there was no Ohms between the TCM wire to the clutch solenoid circuit wire with ignition at lock position as recommended by Alldata.
Something very unusual is that Pin 3 didn't illuminate the test light at all but voltage increased in the DVOM with ignition on to 5v as required. Why is that please?
There was continuity in the TCM to clutch solenoid control circuit wire. But no Ohms from the TCM to the clutch solenoid circuit wire when ignition is in off position.
Apr 26, 2025 at 3:17 AM
