Did some more measurements with the following results:
HVAC 8-pin connector, red wire to ground: 2.85 volts.
HVAC voltage drop across resistors (8-pin plug in): 1.46/1.76/2.11/2.45/2.82 volts.
HVAC 8-pin plug black/pink ground wire to ground chassis: 1.2 ohm.
HVAC 6-pin plug black ground wire to ground chassis: 1.1 ohm.
Servo actuator connector drive voltage: 10.9 volts.
Servo actuator connector sensor ground to chassis ground: 0.7 ohm.
Servo actuator connector +5 volts potmeter supply: 5.03 volts.
Regarding the low voltage: I found and read a diagnostic pdf on a dodge forum and it stated the HVAC head voltage (in this case 2.85 volts) to be between 2 and 3 volts and the actuator drive voltage (in this case 10.9 volts) to be above 8 volts. That makes alot of sense. I am a little confused now.
Looks like the BCM controller is not able to reset the actuator to its "default" position. Tried to drive the actuator with 5 volt input to the drive pins (rotate output shaft 90 or 180 degrees) and noticed that when I reconnected it into the car again it rotates 360 degrees and back 360 degrees no matter what position the output shaft had to begin with. Maybe that is a clue to what is wrong?
Oct 31, 2020 at 11:07 AM
(Merged)
