battery needs to be changed
2002 BMW 325
35,000 MILES • 2.3L • 6 CYL • 2WD • MANUAL
JOHN HOWBOWTIT
whats a mod $12 meaning in a obdII scan tool? was pressing odometer reset to get hidden tests then service light came on so I got scanner out & it said mod $12 and some misfire 300 code and in 1000 something code, i erased codes so I don't know exactly which numbers but mod12 for sure, all because battery needs to be changed.
Mar 23, 2017 at 3:37 PM
If the battery voltage is low it will cause all kinds of weird things to happen, I would change the battery and then clear the codes to see what happens.
Here is a guide to let you know what you are in for when changing the battery,
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Please let me know if you need anything else to get the problem fixed.
Best, Ken
Mar 27, 2017 at 4:12 PM
