Hello. After I replaced the battery in my vehicle listed above Bluetec (W166), the driver's side door lock went out of sync with the rest of the doors/hatch. Doesn't matter if I use the fob or either of the interior lock/unlock buttons - or if I manually set all the doors in the same position - as soon as I hit lock/unlock on the fob or switch the driver's door does the opposite of the lock or unlock button I've hit. I've read somewhere that this is a sign that a fuse has blown. After reading all the fuse/pre-fuse diagrams, the only fuse I can find that has anything to do with the driver's door is #253 in the f32/4 pre-fuse box. I cannot for the life of me find that box as I look around under the passenger seat and in the battery box. Hopefully, I don't have to remove the battery to access it - since that's what started this in the first place. Thanks for any help you can provide. Doug Bowman - Charlotte, NC.
Dec 27, 2021 at 8:20 AM
