1993 Mitsubishi Truck rough idle
1993 MITSUBISHI TRUCK
RYN62188
Engine Mechanical problem
1993 Mitsubishi Truck 4 cyl Two Wheel Drive Manual
my truck has rough idle but its fine when you give it gas. i check all the spark plugs, pcv, mass air flow sensor, spark pulg wires, i adjusted the timing but it never got better so i put it back where it was frist at. heres my screen name [email protected]
thanks
Ryan
Apr 25, 2009 at 6:00 PM
When was the last tune-up? if its done recently I suggest you check the idle air control motor/EGR and PCV valves. And also look for vacuum leaks
Apr 25, 2009 at 6:07 PM
