2002 Mitsubishi Triton head gasket
2002 MITSUBISHI TRITON
SHARK73
Engine Mechanical problem
2002 Mitsubishi Triton Four Wheel Drive Manual 196000 miles
Hi there,
My car has had high oil pressure and my mechanic started by looking at oil pump, after finding no fault(9hrs) he tells me oil filter housing has valves, so he looks there and finds damage which is now fixed(4hrs). Puts it back together then says head gasket is gone so we fix that. Upon tightening head he strips thread and has to throw away gasket and helicoil new thread. My question is should I have to pay for the first 9hrs when there was a cheaper fix to look at first and should I pay for 2nd gasket plus labour to re do head? Surely stripping a thread and the wasted gasket is on him as its poor workmanship
Sep 28, 2010 at 4:16 AM
Hi shark73, Welcome to 2carpros and TY for the donation
A blown head gasket will not cause the oil pressure to go sky high, if the oil pump pressure relief valve is stuck closed it will cause the oil pressure to go high. A problem with the oil filter will cause a low oil pressure-If its me I won't give him a penny-He messed-up he should pay the price due to his inaccurate diagnosis. Best take your vehicle somewhere else or he's gonna do more damages-Good Luck
Sep 28, 2010 at 4:32 AM
SHARK73
Problem now is I have to get car off him! Is stripping a thread common or only done through fault. I guesss fault
Sep 28, 2010 at 4:37 AM
Due to his carelessness
Sep 28, 2010 at 4:42 AM
