2004 Mitsubishi Outlander Oil Pressure Light Goes on when I
2004 MITSUBISHI OUTLANDER
62,000 MILES • 4 CYL • AWD • AUTOMATIC
MRGR8TOY
My Outlander (apart from what I am about to write) has run problem free for 4 years. Currently tho, when I idle the oil pressure warning light comes on. The oil is full, clean and new, recently changed (1200 miles). When in motion the light does not come on. I have also noticed that when idling at a stop light, if I move my steering wheel from side to side the light turns off.
I am assuming I have a sensor problem, but unsure which sensors I should be looking at.
Thanks
Aug 13, 2008 at 7:28 AM
MMPRINCE4000
  • 8,548 POSTS
Check oil pressure with a mechanical gauge. If OK then replace the oil pressure sender and inspect the wiring to it to make sure it is correctly routed and the wires are not frayed/burnt.
Aug 14, 2008 at 6:27 AM
