Transmission Fail safe Re- set
MITSUBISHI
HIREDGOONZ
:?: :?: :?: 1993 Miti. Eclp. 1.8 L. auto, 100K recent replaced motor from a 1994 , now trans is stuck in [b:0db0a38017]Fail Safe[/b:0db0a38017], how the heck do u un-do that ? please, (by fail safe i mean it starts out in high gear) , even if you manually shift into 1, 2 or any gear, has reverse , there was NO problem with tranny b4 engine was repaced and it was towed < NOT on a flat bed. :?: :?: :?:
Jan 6, 2007 at 11:20 AM
CARUNDELL
  • 602 POSTS
[quote:a586299098="HiredGoonz"]:?: :?: :?: 1993 Miti. Eclp. 1.8 L. auto, 100K recent replaced motor from a 1994 , now trans is stuck in [b:a586299098]Fail Safe[/b:a586299098], how the heck do u un-do that ? please, (by fail safe i mean it starts out in high gear) , even if you manually shift into 1, 2 or any gear, has reverse , there was NO problem with tranny b4 engine was repaced and it was towed < NOT on a flat bed. :?: :?: :?:[/quote:a586299098]
Hey hired,
In your underdash fuse panel there should be a fuse marked TCM or Trans. Pull this fuse for 10 mins, then re install. Let us know!
Chris
Jan 7, 2007 at 6:32 AM
