thermostat
MITSUBISHI
AC22
where exactly im my thermostat on 1999 mits, gallant?
May 25, 2006 at 3:01 AM
SDALTON19
  • 87 POSTS
flashing check engine light means misfire severe enough to cause catylist damage the misfire probabley only occurs at start up you should have it checked out
May 27, 2006 at 9:52 PM
GURILLAZ
  • 4 POSTS
[quote:a7a373482e="sdalton19"]flashing check engine light means misfire severe enough to cause catylist damage the misfire probabley only occurs at start up you should have it checked out[/quote:a7a373482e]
It is when the car is turned off and it only flashes once while the car is in park and turned off. ALl scans say my car is fine. No check engine light on while driving But my tracation control will turn on and off by it self. Worry about that or not ????
May 27, 2006 at 10:48 PM
