Power Window
MITSUBISHI
MOHAMMADZAMRI
Proton (Mitsubishi), yr 1993, 1300cc, Manual.
I have the car for 14 years, a year ago the driver's side power window had a problem. It intermittenly operate. Sometimes it will open for few inches and stop, got to wait for a while until it works again. The same goes when it want to close. I have checked the switch and relay. They are fine. So, I changed the motor and clean/greased the mechanism. After 2 months, the problem re-appear. I have touched the relay and it is hot. Is the relay the problem or I have to change the motor again. How to prevent the motor to consume more current, which will tripped the breaker.
Nov 15, 2007 at 12:15 AM
ZACKMAN
  • 4,202 POSTS
Should have replaced the relay before you went into trouble replacing the motor.
Feb 25, 2009 at 12:56 AM
