1986 Mitsubishi Mighty Max PU, 5 speed, 157K, 2.0
This is an extremely well maintained truck. I began to have starting problems. Turn key and everything works, but the starter was not cranking the engine. I would tap the starter/solenoid with a hammer and it would then start after that. I replaced starter with an exact matching used one and carefully reconnected the wiring for this replacement. Now, it cranks over every time I turn the key, but it will not fire up until the key gets released from the cranking start position, back to the normal running position. I need your help!
May 27, 2007 at 2:21 PM
