my heat stopped working its blowing cold air now
MITSUBISHI
LILMIZZPEACHEZ
i have a 2003 galant it has about 61000 on it and the heat stopped working in it 2 days ago now it only blows cold air i was told i should check the antifreeze, coolant, or replace the thermostat please help me
[img:dd8f843f63]http://www.2carpros.com/forum/automotive_pictures/53519_peachez2_1.jpg[/img:dd8f843f63]
Jan 12, 2007 at 7:35 AM
SERVICE WRITER
  • 9,123 POSTS
Nice Pic :wink: First check the coolant level if good and the thermostat is original, it is a reasonable possibility. Not a real expensive cost-$100? Takes a little less than an hour to do.
https://www.2carpros.com/forum/automotive_pictures/30961_old_man_1.jpg
Jan 12, 2007 at 8:33 AM
SMONTESI
I have a 2003 Mitsubishi Eclipse. That happened to me and I checked the coolant fluid, filled it and the heat worked again.
I hear thats a common thing with Mitshibishi's.
Jan 22, 2007 at 7:04 PM
SERVICE WRITER
  • 9,123 POSTS
[quote:fb80298265="smontesi"]I have a 2003 Mitsubishi Eclipse. That happened to me and I checked the coolant fluid, filled it and the heat worked again.
I hear thats a common thing with Mitshibishi's.[/quote:fb80298265]
Losing coolant is not normal to any car, it just doesn't diasappear for no reason. On yours, the cause isn't found....yet. The heater core is the first thing to lose coolant flow due to it's location, thus it's abilty to keep heat in the passenger compartment.
Jan 22, 2007 at 8:28 PM
2CARPRO JACK
  • 11,533 POSTS
Might want to try parking your car an a clean spot, then when you leave back up and look for coolant on the ground. Might give you a place to start
Jan 23, 2007 at 7:46 AM
