Mitsubishi, Montero sport ls 2001
2001 MITSUBISHI
FAERIEBRIGHT
How do I replace the transmission filter and the pan gasket?
Jun 13, 2006 at 5:16 AM
MITSUTECH
  • 17 POSTS
first drain fluid then remove all pan bolts may need to tap pan with rubber hammer clean off gasket with wire wheel from pan and use razor on tranny case. remove two 10mm bolts from filter. pull filter down becaerfuul you could get wet. remove o-ring frome valve body. install new filter. make sure you put magnets back in pan. use good sealent not too much 1/4in bead on pan then install.
Sep 2, 2007 at 11:45 AM
