mitsubishi diamante 1994 es(sohc), 190000, V6
1994 MITSUBISHI
BUD1984
I recently found out that on the cv joint there is a part called a spindle or knuckle that connects to the motor. i found out the problem was that the bolts were missing on the spindle. i asked the manafacturer what size bolts go with this spindle and they told me that it was a 12x50 but it turned out to be to big. they did not tell me all information on the size, thread and all info about the bolt. I was wondering if you guys know all information about the bolts that go on the spindle or knuckle. your response would highly appreciated. Thank you and i will work on the donation for you.
Nov 18, 2007 at 5:23 PM
Are you talking about the two bolts that goes to the bracket assy see below or the spindle nut? Am little bit lost here, help me help you.
https://www.2carpros.com/forum/automotive_pictures/12900_bracket_2.jpg
www.eautorepair.net
Nov 19, 2007 at 1:09 AM
BUD1984
On my cv joint there is a spindle or knuckle as the dealership said. it may be called a bearing bracket. i think it may be called the bracket assembly But from the diagram you sent me, the bracket goes a little more upwards with two bolts spots laterally(up and down) that when the bolts are inserted goes into the motor mount, not with two bolt spots side by side. I would like to know the size of these bolts if you can inform me. Your response would be highly appreciated and i am still trying to work on the donation. thanks
Nov 19, 2007 at 11:23 AM
When In neutral and i push my car it makes a popping or clic
Posted at Wed Oct 31, 2007 12:41 pm
By bud1984, New to the forum
Give Feedback | Votes: 0
I have a 95 Mitsibushi Diamante ES with about 190000 miles with an V6 engine. I would like to know the reason that when i put my car in neutral and give it a push a clicking noise occurs. But when I look at my CV Joint it seems okay. Once before i replaced a bolt on some type of bracket which i think gave support to the CV Joint because it was doing the same thing but i do not know what it is called. Do you know what is the name of the bracket and what may be wrong with my car?
Axleshaft Bearing Kit P/N MB620810
Nov 19, 2007 at 11:47 AM
