engine Tapping
MITSUBISHI
URBS13
  • 13 POSTS
I've got a newer model 93 glant, my speedo lights are not working even though all fuses and bulbs are fine. one of my rear night lights dont work but brake lights do. also i can hear a knocking when in 5th gear going more than 90kmh. what can i do to solve this?
Jan 7, 2007 at 8:00 PM
SERVICE WRITER
  • 9,123 POSTS
Not sure on the speedo.
The night light? PArking light? If you mean parking light, you probably need a bulb. There is a double filiment bulb that will light when brake is on and slightly dimmer with the parking light.
Would you call the knocking a rattle, like marbles in a tin can noise?
Jan 7, 2007 at 8:25 PM
URBS13
  • 13 POSTS
Yeh the speedo light not working is annoying, but i've changed the rear light bulb with the double filament and it still doesn't work.
The knocking is kind of like a low pitch sort of sound like a golf ball continuously hiting the underside of the car near close to my feet
Jan 7, 2007 at 9:41 PM
SERVICE WRITER
  • 9,123 POSTS
Is is possible that the exhaust moves into a postion that is is bumping the floor? OR a heat shield that is moving at the higher speeds? Stick you nose under and do a little feeling around for anything that may be loose.
You'll need to check for power and good ground back to that socket if the bulb is good and installed correct. Sometimes there is a ground tab that needs a little manipilation.
Jan 7, 2007 at 10:02 PM
URBS13
  • 13 POSTS
ahh yes quite possible ill have to have a look later when i finish work. It only noticably happens when in 5th at over 90kmh if what you said is true wouldn't the noise happen in all gears?
Jan 7, 2007 at 10:18 PM
SERVICE WRITER
  • 9,123 POSTS
Not necessarily. When your in fifth gear, you are running at higher speeds and have an increased air flow throughout the car. IF you stick your arm out the window with a loose jacket on you'll see how the sleeve flaps like crazy. Now hold you hand out flat and slightly pitch it like a flap on an airplane. You whole arm goes up and down as you change your flap..err hand. Transfer that theory to the car. A loose heatsheid that is thin will do the same. It may be pushing up on something such as a hose. It can be moving itself or somthing else and hitting the floor board or anthing that transfers the energy to your feet.
Jan 8, 2007 at 5:39 AM
URBS13
  • 13 POSTS
Ahh ok i see. Thanks :) I'll grab some ramps and have good look.
Jan 8, 2007 at 3:00 PM
