Engine Lifter
MITSUBISHI
AARONHUI
  • 4 POSTS
I have a 99 Mit Eclipse Spyder with a 2.4L SOHC 4G64 Engine. The engine has 133,000 miles on it.
Recently, I was driving and while accelerating, the engine chokes on me and then I heard loud ticking noise from the engine. I took it to a few shops to look at it, and they all think that it is the lifter problem.
They all recommend me to get a used engine and replace the whole engine. Is there an other way to correct the problem? Can I simply replace the lifters?
Thanks.
Aaron
Aug 20, 2007 at 3:20 PM
MIKE H R
  • 3,094 POSTS
Did they say it was the lifters or think it was? Lifters can be replaiced, but it is time consumming. Get estimates on repairing the lifters from a couple of garages and get estimates on how much a used engine would cost with instalation.
Aug 20, 2007 at 3:33 PM
AARONHUI
  • 4 POSTS
They said it was the lifter. Could it be something worse than that? I have also gotten some quotes for replacing the engine, it will probably costs about $2000. But I just can't find an engine right now to get it fix? Hard to find 4G64 engines. What would be your recommendation?
Aug 20, 2007 at 3:40 PM
MIKE H R
  • 3,094 POSTS
just looked around a little found that c jee.com/mitsubishi.htm and e bay motors have some, on e bay they range from 500 to 1500
if you can't get through just type in
used mitsubshi 2.4 sohc 4g64 engine on you browser
Aug 20, 2007 at 4:11 PM
AARONHUI
  • 4 POSTS
Does the Galant 2.4L SOHC 4G64 engine fits the eclipse?
Aug 20, 2007 at 4:25 PM
MIKE H R
  • 3,094 POSTS
I believe it is the same engine, there might have to some minor changes but should work, but not possitive. Did you check out the other inf I sent to you
Aug 20, 2007 at 4:41 PM
AARONHUI
  • 4 POSTS
I have checked the other info, but I only found 00-02 2.4L SOHC engines for eclipse, which I know for sure is a different engine. I also need one that fits the manual transmission, and I found a few that are for automatic.
Can you send me the direct links to the different source you have found the engine?
Thanks
Aug 20, 2007 at 5:11 PM
MIKE H R
  • 3,094 POSTS
I looked at cjee.com/mitsubishi.htm and the other was just e-bay motors.
Aug 21, 2007 at 2:35 PM
