Car keeps shutting off
MITSUBISHI
BRYANMAC23
I have a 2001 Galant. After a normal start up the car just shuts off. If I wait about five minutes or so it will start up and run fine. The check engine light comes on for awhile then shuts off. The only thing I have found in common is that it happens when I park with the front of the car at a slight downward angle. I thought it was the oil sensor cutting off the fuel because I was a bit low on oil but I add oil and it is still happening. Other than that I see nothing wrong. Any suggustions would be greatful!
May 22, 2006 at 9:45 PM
GALANT909
when at a stop in idle,the engine vibrates. but when i put in neutral it stops vibrating. sparks plugs replace.fuel iject system clean. belts not changed.
May 29, 2006 at 10:20 PM
