Can't loosen bolt
MITSUBISHI
LSCHRAG
2000 Mitsubishi Mirage, 120,000 miles, 1.8 engine. Can't loosen the crank shaft pulley bolt to change the timing belt. I have tried using a 1/2" electric impact wrench rated at 250lbs. I also tried holding the pulley with a large pry bar and using a socket with an extended handle for more torque. I end-up bending the pry bar. Does this car have a reverse thread on that bolt?? Any suggestions.
Thanks
Sep 16, 2007 at 10:24 PM
CHELLE01N00
try using WD40. i've sprayed it on lug nuts that were rusted and it worked. also used it on the flare nut replacing the fuel filter...
Nov 20, 2007 at 4:05 PM
