Brake fluid on the carpet
MITSUBISHI
CWOODHOUSE
I have been finding brake fluid leaking on the carpet of my 1991 Mit G-VR4. I replaced both the clutch and brake master cylinder, and I still have fluid drip on the floor and under the dashboard is still wet. The brakes seem to work fine, but cant tell why its doing this. only happens when I'm driving for long periods of time, If I just try to pump either clutch or brake at a stop, it doesnt leak.
Does anyone have any ideas what it might be?
Jun 22, 2007 at 11:26 PM
RECKLESSJ
Check your clutch fluid. I bet it's empty or low. My 98' Mits. Eclipse does the same thing. On the eclipse, just above the clutch pedal, is the clutch SLAVE cylinder. I'm not sure as to it's EXACT location on the galant vr-4 but i'm guessing it's similar. Same block (4g63t).
Jul 3, 2007 at 1:16 AM
