Hello, i have a 1996 Mitsubhishi eclipse spyder 2.4L it has 130000 miles and my question is this. My A/C was working fine and all of the sudden it just began to blow hot Air, and now when i first turn on the A/C it works for about 5 minutes then it blow's hot then it works again for another 5 minutes and then hot again. i had a mechanic check to see if i needed freon but was told that it was not leaking freon. what could be causing this to happen, i do hear the compressor clutch kick in when i turn on the A/C.
thank you
thank you
Jun 4, 2007 at 11:40 AM
