I have a 99 eclipse RS std transmission vehicle with 93,000 miles. THe check engine light came on and the mechanic says it has a vacuum leak that is causing the problem. Where would be the most likely area that this leak would occur? They did the smoke test thing and could not find the area where the leak was coming from. Or could it be from the O2 sensor needing to be changed?
Thanks
Thanks
Jun 13, 2007 at 11:34 AM
