98 ECLIPSE - HESITATION/SPUTTERING/ STALLING
1998 MITSUBISHI
MITCHE2001
CAR: 1998 MITSUBISHI ECLIPSE - 2.0 NON TURBO - 84K MILES - AUTOMATIC.
PROBLEM: The car hesitates and sputters when accelerating. Wants to leach forward when at a stop and tends to stall when trying to accelerate from the stopped position.
WORK DONE: I have replaced the Fuel Pressure Regulator, Fuel Filter, Spark Plugs/Wires, PCV, all Vaccum Lines, Throttle Positon Sensor and I removed the Fuel Injectors and verified they work and are not clogged. There are no computer codes. I am at a complete loss. Does anyone have any ideas what may be wrong?
Oct 15, 2007 at 8:43 AM
CARUNDELL
  • 602 POSTS
[quote:12477ce4b6="mitche2001"]CAR: 1998 MITSUBISHI ECLIPSE - 2.0 NON TURBO - 84K MILES - AUTOMATIC.
WORK DONE: I have replaced the Fuel Pressure Regulator, Fuel Filter, Spark Plugs/Wires, PCV, all Vaccum Lines, Throttle Positon Sensor and I removed the Fuel Injectors and verified they work and are not clogged. There are no computer codes. I am at a complete loss. Does anyone have any ideas what may be wrong?[/quote:12477ce4b6]
Hey Mitche2001,
A faulty/biased O2 sensor would cause that condition. Additionally some other things to check would be the output of the coilpack (a nice white/blue spark or w/ a kv meter if ya got one), coolant temp sensor may be faulty, creating a lean mixture causing the skip/hesitation. Let me know!
Chris
Oct 15, 2007 at 8:51 AM
MITCHE2001
Chris,
Thanks for your help. When I went to pull the plug wires again, I found them covered with oil. I had developed an oil leak into the spark plugs. I replaced the valve cover gasket and bought new wires. All the problems have been solved.
Thanks again,
Mitch
Oct 19, 2007 at 10:15 AM
CARUNDELL
  • 602 POSTS
[quote:324b78523a="mitche2001"]Chris,
Thanks again,
Mitch[/quote:324b78523a]
Thats great news mitch!
Chris
Oct 19, 2007 at 1:31 PM
