95 mitsubishi mirage alternator belt
1995 MITSUBISHI
STEVO160
1995 mitsubishi mirage 107,000mi. 1.8 liter. Last week the alternator belt began squealing. It did this for about a week and then broke. I put a new one on. It started to squeal again, so I tightened it each time, but then it would start to sqeal again a little bit later. It lasted for about 4 days and then broke. What's going on? I noticed it squeals a little more when the heat is on.
Jan 26, 2007 at 11:25 AM
2CARPRO JACK
  • 11,533 POSTS
Did you spin all the pulleys it goes on to be sure nothing is coming apart? Sounds like abearing is going out somewhere on the front of the engine
Jan 26, 2007 at 12:25 PM
MATHIASO
  • 1,209 POSTS
You may have a V type belt.
do you adjust the belt tension?
Because you said this" It did this for about a week and then broke. I put a new one on. It started to squeal again, so I tightened it each time, but then it would start to sqeal again a little bit later. "
Jan 27, 2007 at 8:02 AM
