[b:7951f4661b]95 Mitsubishi Mirage 1.8 liter 105,000 miles[/b:7951f4661b]. The oil mostly leaks at high speeds or when the car is working hard. At 70mph all the oil will leak out in about 150 miles. When I don't go on the highway it barely leaks at all. I smell burning oil when I go fast or uphill.
There is no smoke coming out of the exhaust or under the hood. When I look under the car I see oil dripping down the oil pan and pretty much on everything else near the engine.
I had the valve cover gasket replaced and I replaced the oil pan seal (no gasket available for oil pan). Neither of these had any effect. If anything, the problem has worsened.
Jan 10, 2007 at 1:49 PM
