2001 Other Mitsubishi Models clutch
2001 MITSUBISHI
46,000 MILES • 4 CYL • 4WD • MANUAL
S.HOLLY1811
i have a shogun pinn gdi clutch pedal has gone to the floor hydrolic clutch can you help
Aug 13, 2008 at 5:57 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Check the hydraulic fluid, if its gone, check the slave cylinder at the gearbox for a leak, (pull back the rubber dust boot) if it is wet it is faulty, also check the master cyl, this is a bit harder but look under the dash and see if there is any fluid leaking where the pedal push rod enters the master cyl, start here.
mark (mhpautos)
Aug 13, 2008 at 7:45 AM
