1995 Other Mitsubishi Models Problems I have 2.
1995 MITSUBISHI
94,000 MILES • 6 CYL • FWD • AUTOMATIC
SHANEE86
I have 2 problems first my RPM's sometimes go up and down like slip and speed is staying same just started didn't do before. But in over drive it slips all over on rpms and won't hardly go. Also my passenger front seat won't go back and forth like straight back on bottom anymore. It used to it is not automatic just on like a track or something but can't find anything in track some said might be the spring and I check seems connected? I have a Mitisubushi 3000gt sl thanks.
Jun 24, 2008 at 6:27 PM
KHLOW2008
  • 41,814 POSTS
Hi shanee86,
The trans is slipping, check the ATF level, it might be too low.
The passenger seat tracks might be stuck due to coins or other foreign materials gettiing into the rails.
Jun 25, 2008 at 11:52 AM
SHANEE86
[quote:28a1e54a81="KHLow2008"]Hi shanee86,
The passenger seat tracks might be stuck due to coins or other foreign materials gettiing into the rails.[/quote:28a1e54a81]
I have check transmision fluids and oil fluid the are both way over full like 3x the line that bad and what can I do if so?
Jun 25, 2008 at 6:11 PM
KHLOW2008
  • 41,814 POSTS
Hi shanee86,
Overfilling of the trans fluid and engine oil can cause problems with lack of accelerating power.
You need to drain some out, easiest way is to remove the drain plugs and let out the required amount.
If you did topping up without checking the level, releasing some would get the job done, but if the level increases themselves, there might be some other problem like water getting into it.
Is the ATF color reddish, brown or milky?
Engine oil color?
Jun 26, 2008 at 9:46 AM
