1994 Other Mitsubishi Models No output from New Alternator
1994 MITSUBISHI
17,900 MILES • 4 CYL • 2WD • AUTOMATIC
CINDI KERN
Mirage. Just replaced battery & alternator. Had the fuses checked & seemed fine. Yet the new alternator will not put out a charge. Belt and connections seem tight, cannot find any loose wires. Had the car a month and was running fine, my son cleaned the engine (no water) WD40 only and now it won't charge. Please advise where to next? I'm $250 into it now and still the same problem.
Thank you
May 17, 2008 at 11:44 AM
See below wiring diagram this is the best I could do with the image I go further you won't see it-
https://www.2carpros.com/forum/automotive_pictures/12900_alty_18.jpg
May 17, 2008 at 2:28 PM
