1994 Other Mitsubishi Models knocking
1994 MITSUBISHI
144,000 MILES • 6 CYL • FWD • AUTOMATIC
BRPIACH
there is a knocking coming from inside the left cylinder head or at least i think so but its on the left side of the engine & i was thinking about just ordering a new head online but i wanted a second opinion also the timing belt is fine ive had a few people try to sat its the timing belt but i was wondering if it could be the tensioner or something simple to fix?
Aug 28, 2008 at 6:56 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This is just to hard to make a judgment on with out hearing the noise, there is a lot going on in the engine that can make that type of noise, i would get a mechanic to have a listen first, you don't want to be getting an expensive head if its not the problem, sometime these problems just have to be heard first hand before you can make a diagnosis.
mark (mhpautos)
Aug 28, 2008 at 8:19 AM
BRPIACH
i already took it to a mechanic and they tried to say it was the timing belt but i looked & the timing belt is in tacked also the knocking is coming from the front of the engine either under the head or in it but i opened it up & the cams are fine nothing is loose but im still not sure
Aug 29, 2008 at 6:28 PM
