1993 Other Mitsubishi Models 1993 3000gt Vr4 Won't Start, Pl
1993 MITSUBISHI
17,600 MILES • 6 CYL • 4WD • MANUAL
MUNKEYPHANTOM
Recently bought vr4 that hadn't been running for 3 yrs. Turns over/cranks, but won't start. Has spark. Has fuel pressure. We think the injectors may not be working, but not sure because there is power, 12V, to the injectors when ignition is on. We also took an MFI relay from another 3000GT and that didn't help. Could it be the ECU and are there are any less expensive repairs we could try first?
Any advice is greatly appreciated!
Jul 21, 2008 at 10:31 PM
SERVICE WRITER
  • 9,123 POSTS
HAve you checked for compression...as in a possible timing belt that broke.
IF so, check the timing if it has skipped a tooth.
Jul 23, 2008 at 5:53 AM
