1993 Mitsubishi CLUTCH PEDAL
1993 MITSUBISHI
110 MILES • 4 CYL • 2WD • MANUAL
LINDASAN
WE HAVE REPLACED THE CLUTCH PEDAL ON OUR 1993 MITSUBISHI MIGHTY MAX TRUCK 2 TIMES AND EACH TIME IT BREAKS, HAVE YOU KNOWN OF ANY PROBLEMS WITH THESE CLUTCH PEDALS?
Dec 9, 2007 at 1:59 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Is the clutch pedal failing in the same place? i would think this is most unusual, i would check with a dealer to see if there are any field reports on this, you may be just unlucky as well. if it is failing in the same place Where and how? you may be able to strengthen it up so it will last the distance.
Mark (mhpautos)
Dec 9, 2007 at 5:45 PM
