1990 turbo eclipse with charging issues
1990 MITSUBISHI
KUB213
1990 mitsubishi eclipse turbo 193,000, the car won't charge i have 3 alt. that test good on the ,bench 2 won't work in the car , replaced battery, all connections cleaned and tight replaced all fuses, relays, light circuit functioning properly , resistances on wires appear to be ok,third alt worked for 300 miles after i had these problems but went back to same condition, any clue, could a bad ecu affect this? these cars are known for caps leaking in the ecu's. thanx in advance
Mar 5, 2006 at 8:24 PM
ANTONIOTGSX
  • 18 POSTS
If you are loosing alternators.... then I come to conclude.... You have high power STEREO SYSTEM that is blowing your altenators......
You have a broken altenator harness.....
You have a bad electrical ground in your car someplace......
dose your car have air conditioning.... power steering.
if so. check the air conditionig and power steering units.....
if not... GET A NEW BATTERY
Mar 9, 2006 at 7:45 AM
