1982 Other Mitsubishi Models ignition
1982 MITSUBISHI
15,600 MILES • 4 CYL • 2WD • MANUAL
SKYLINE
  • 7 POSTS
hi i have a astron g52 motor that i cant get too fire it has spar but wen i check the point 4 spark it sparks back too the coil also the starter is verry sluggish with a new battery any help would b great thanks
Dec 29, 2007 at 3:30 PM
What kind of ignition system do you have? Is it electronic or conventional distributor with contact points?
Dec 29, 2007 at 5:08 PM
SKYLINE
  • 7 POSTS
[quote:d39a1a4c96="rasmataz"]What kind of ignition system do you have? Is it electronic or conventional distributor with conitact points?[/quote:d39a1a4c96]it ia a conventional dizzy
Dec 29, 2007 at 10:42 PM
There should be only one wire going in the distributor that's coming from the coil negative that goes to the point/s-try gapping it and see what happens.
Dec 30, 2007 at 12:49 AM
SKYLINE
  • 7 POSTS
[quote:30222a36a2="rasmataz"]There should be only one wire going in the distributor that's coming from the coil negative that goes to the point/s-try gapping it and see what happens.[/quote:30222a36a2]hi i have had all the wireing removed as it is a race car can u please tell me were all the wiring goes eg. starter to battery neg to car too batt positive coil 2 power ect ect thanks 4 your help and wat u mean by gapping it
Dec 30, 2007 at 3:56 PM
gapping it-means adjust the point gap/clearance
starter to battery neg to car too batt positive coil 2 power ect I dont' understand this can you be specific to what are you trying to tell me.
Dec 30, 2007 at 4:01 PM
SKYLINE
  • 7 POSTS
[quote:d3db1b3be7="rasmataz"]gapping it-means adjust the point gap/clearance
starter to battery neg to car too batt positive coil 2 power ect I dont' understand this can you be specific to what are you trying to tell me.[/quote:d3db1b3be7]i am rewiring the car 4 a race car no factory wiring is left can u tell me how 2 wire it up i may have done it wrong also the starter is verry sluggish
Dec 31, 2007 at 12:51 AM
The wires going to the coil disconnect it-isolate it from ground, turn igniton switch on find the wire that has power on it and put that wire on the positive side of the coil the others goes to the negative of the coil.
Dec 31, 2007 at 12:56 AM
SKYLINE
  • 7 POSTS
[quote:175051f3ff="rasmataz"]The wires going to the coil disconnect it-isolate it from ground, turn igniton switch on find the wire that has power on it and put that wire on the positive side of the coil the others goes to the negative of the coil.[/quote:175051f3ff]it has spark and power but starter is real slugish even with a new battery iv tried 2 starters it liike the engine has real high compression but i cant get the engine too wind ova fast enugh any ideas thanks
Jan 1, 2008 at 12:59 AM
Sounds tight somewhere-open the plugs out and investigate-could be the valves not opening or tight engine bearings-could be anything internally. Check it out.
Jan 1, 2008 at 1:15 AM
SKYLINE
  • 7 POSTS
[quote:386ef54c4e="rasmataz"]Sounds tight somewhere-open the plugs out and investigate-could be the valves not opening or tight engine bearings-could be anything internally. Check it out.[/quote:386ef54c4e]hi i have been told by the person i got it off that it shot a bottom end shouldnit still run tho :?:
Jan 2, 2008 at 2:18 AM
