I have just developed an unusual problem with signal lamps. When I use the turn signals with the headlights off, everything works fine. When I turn on my running lights or my headlights, the left turn signal light on the dash comes on and stays on steady. Outside the car the left turn signal in the front and the back are lit and on steady. The left headlight is on but the right headlight is out. If I use my left turn signal with the headlights on, I get a slight bit of blinking but also the navagation screen in the center of the dash also gets brighter and dimmer along with the signal. I know the right headlamp works because if I pull the turn signal lever towards me to turn the brights on and hold it and then twist the lever to turn the headlights on, both headlights do come on.
Strange group of happenings. Any suggestions? I have not taken the car into the dealer yet for a scan of the lighting controls. My standard OMD II scanner does not give any faults.
Thanks to anyone who can respond.
Mike
The answer needs to be more than just get it scanned.
Mike
Jul 18, 2010 at 3:58 PM
