2001 Mitsubishi Montero Noise coming from Serpentine belt
2001 MITSUBISHI MONTERO
88,000 MILES • 6 CYL • 4WD • AUTOMATIC
APEARSON
  • 6 POSTS
My '01 Montero has an almost metal on metal sound coming fromt the belt area. There are no performance issues. The noise does go up and down with the engine speed when the throttle is pressed. It just started. Do I have a pulley going out, alternator, or water pump? Whats going on? Please help.
Apr 21, 2009 at 1:58 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Assuming you don't have a stethascope cut a 3ft lenght of 1/4 to 5/16 hose. Being very careful one end in ear the other move around runnig pullies see if you can ID noise.
Let me know
Thanks for donate
Apr 21, 2009 at 3:57 PM
APEARSON
  • 6 POSTS
The noise does not seem to be coming form the alternator, but it was so noisy on the pulley above and below the alternator. The pulley below was wiggling a bit, and when the motor is off it is the only pulley that has any play in it. I don't know what that pulley is for though. The motor sounds like a diesel, but again, no performance issues. Looking at the motor from the front of the car, on the left you have a pulley up top, I think it is the water pump?, then to the left and lower is the alternator, and then almost level but to the right is another pulley. This is the one that is moving a little bit and the one I think is making the noise. Is it ok to drive it like this? Do you have any ideas? Thanks for your response and help.
Apr 22, 2009 at 12:12 PM
DOCFIXIT
  • 18,828 POSTS
That is the tensioner pully and if movement then bearing faulty. Would not drive too much before repair. You do have three belts right?
Apr 22, 2009 at 4:04 PM
APEARSON
  • 6 POSTS
No, it is just the one belt.
Apr 22, 2009 at 5:26 PM
APEARSON
  • 6 POSTS
How easy is it ot repair this pulley by myself? It doesn't look to complicated, should I give it a go? Thanks for your help.
Apr 23, 2009 at 12:46 PM
DOCFIXIT
  • 18,828 POSTS
Not hard at all but you sure there is only one belt. Is this a 3.5L V6?
Apr 23, 2009 at 4:08 PM
APEARSON
  • 6 POSTS
Yes, 3.5v6. One belt.
Apr 23, 2009 at 4:31 PM
DOCFIXIT
  • 18,828 POSTS
I have no info for one belt all my diagrams show three seperate belts to run all the acessories.
But pully is still easily replaced.
Apr 23, 2009 at 4:40 PM
APEARSON
  • 6 POSTS
replaced the tensioner pulley last night and al symptoms are gone. That was our culprit. It was a fairly easy job and I got it done in about 30 minutes. The old pulley was practically seized up. Thanks for all of your help.
Apr 24, 2009 at 11:11 AM
DOCFIXIT
  • 18,828 POSTS
Glad to hear You did good diagnostics.
Apr 24, 2009 at 3:18 PM
