2001 Mitsubishi Montero Codes P0715 and Transmission code 2
2001 MITSUBISHI MONTERO
75,000 MILES • V8 • 4WD • AUTOMATIC
TTNAK
The Neutral light started flashing when my car is in D,3,2 and Low but not in R. Service engine light is on. Codes are P0715 and my mechanic said also code 22 and that they all were Transmission codes. What to do?
Jul 11, 2008 at 7:40 PM
KHLOW2008
  • 41,814 POSTS
Hi ttnak,
P0715 = Input speed sensor A circuit malfunction.
Code 22 = Kickdown servo switch does not turn ON when in 2nd or 4th gear.
The input sensor is located outside the trans, so I would suggest checking it for problem first. If it is not the sensor, then it is the trans internal fault which might require a rebuild.
Code 22 is the by product of P0715
Jul 12, 2008 at 1:45 PM
WAYO GARZA
Hello ttnack
I have same problem as yours, could you fixed it and how?
Please advise
Thanks
Oct 27, 2008 at 11:05 AM
