2001 Mitsubishi Montero brake mastercylinder area
2001 MITSUBISHI MONTERO
78,000 MILES • 6 CYL • 4WD • AUTOMATIC
DANIELPEREZ
makes noise from master cylinder when motor running and when ignition is on, seems like a reservoir attached to the master cylinder is making the noise, can you tell me what is wrong
Nov 18, 2008 at 6:13 PM
JAMES W.
  • 2,394 POSTS
Do you have a vacuum power booster behind the master cylinder? If yes, check the vacuum hose and fitting for vacuum leak.
Nov 18, 2008 at 7:19 PM
