I have an '01 Montero limited. low miles, great condition, excellently maintained. Stopped abruptly while being driven approx 2-3 minutes after start up. Ran perfect previous. The timing belt slipped 1 tooth on the crank, but the heads/pistons are fine. Belt has been replaced, and engine timing set correctly. Passed compression test with flying colors. Still won't start. CKP, CMP, TPS, MAF, and AIC motor tested with PICOscope and working, coil packs are fine, >55lbs fuel pressure. Fuel injectors are pulsing. No codes in ECU, and ECU displaying live data, and data looks good. I have air, fuel, and spark. Just won't run. What the heck????
Oct 20, 2009 at 12:01 AM
