2000 Mitsubishi Montero HELP!!
2000 MITSUBISHI MONTERO
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEREMIAHBW
2000 montero changed oil and filter cranked car and couldn't get any gear to drive. all gears where like they were in neutral. pressed a/t button and had same reaction. Finally put it in to low gear tacked it slowly to approx 4200 rpm and it moved foward 2 feet and blew large amount of smoke from tail pipe. if you crank car and let idle smoke is at contnuious flow. then i went to drain the oil out and only about 25% of a quart came out. there are no leaks meaning drain bolt and filter are tight or any noticable sign of leak. i put 4.8 quarts in as manual suggested. whats going on here?! Also still wont move in any gear.
Feb 15, 2009 at 8:29 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
what colour is the smoke, blue is oil burning, i would check the trans oil level and re fill the engine oil and check level before running if smoke is continuous, stop and pull spark plugs and check for a plug that is oil fouled, do a cont test or leak down test on that cylinder to see if you have a ring problem, start here.
mark (mhpautos)
Feb 16, 2009 at 2:46 AM
