1998 Mitsubishi Montero high mount stop ;ight
1998 MITSUBISHI MONTERO
69,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHCR007
can someone please instruct me how to access the brake light bulbs located in the high mount stop light so that I can replace the bulbs with the new brighter syslvania 921 silverstar bulbs.?
Mar 23, 2010 at 6:30 AM
CARADIODOC
  • 34,306 POSTS
No need to blind other drivers. If the lamp is not as bright as it should be, look for a deformed or dirty lens. If the bulbs are not getting full brightness, measure the voltage on both wires. If the other brake lights are normal brightness, look for any voltage on the ground wire for the high-mount light. The ground wire must have near 0 volts. If there is some voltage, look for a loose or corroded connection where the wire is bolted to the body. The brighter bulbs will melt the lens and housing over time.
caradiodoc
Mar 23, 2010 at 5:11 PM
Check your other post
Mar 24, 2010 at 11:30 PM
