Engine Cooling problem
1998 Mitsubishi Montero 6 cyl Four Wheel Drive Automatic 200K miles
My 98 Montero gets hot in traffic on warm days. If I am moving at 40+ MPH the truck temperature is OK but when in stop and go traffic the temp quickly heats up. I have flushed the radiator and changed the thermostat but that did not fix the problem. When I first start the engine the fan appears to be working fine but I can't tell when I am moving down the road. Is this a fan clutch problem? If so how do you change the fan clutch?
Jun 29, 2008 at 11:09 PM
