1998 Mitsubishi Montero car sputters
1998 MITSUBISHI MONTERO
GIRLSCORPIO
Engine Performance problem
1998 Mitsubishi Montero Automatic 120000 miles
My car tends to sputter or feels like it is skipping. As soon as I put it in reverse The sputtering is at its worse.It is also slow in its exceleration, but when It gets up to speed its fine.
Sep 22, 2010 at 12:41 PM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Sep 22, 2010 at 4:58 PM
